Series2 16V turbo hesitates/stutter
Moderator: Huib
Luke
Re: Series2 16V turbo hesitates/stutter
Post by Luke » 02 Nov 2006, 17:45
interesting... i'm thinking of going the same route... i want 220bhp :)
Pierre
Re: Series2 16V turbo dyno (final)
Post by Pierre » 11 Nov 2006, 12:23
Dyno run today again. Marginally better with new settings. 155 KW @ 5200 RPM and 336 Nm @ 3750 RPM.
Looks like the limit for this turbo (standard T3). Not sure what the trim of this T3 is, will have to strip to find out (unfortunately), unless someone can forward the details. Looks like 40/50 trim. Will probably require a T3 with 60 trim and 0.82 turbine A/R Ratio for about 185 - 200 KW (or a GT25 300HP model)
Boost starts to drop off from 5500 RPM to 0.9 bar at 6500 RPM. Looking at this info now then the stock injectors would have been fine for this setup......
Return to “51 Thema”
