What is the ecu number for the 8v, i have a new 8v turbo and has a different ecu number than the other 8v turbo i have. Does anyone know what the factory number is for the ecu? The two numbers are 601 b and 601 d or e(can't remember and car not here)
Cheers
8v turbo ecu
Re: 8v turbo ecu
cheers one is Med 601b and the other is Med 601d.
Don't suppose anybody knows what a Med 601d is from?
Re: 8v turbo ecu
The 8V turbo has the Digiplex 2 ignition system as far as I know. It is marked MED 440A
The 16V engine has the Microplex ignition system marked MED 601E
Does your car have a distributor or twin coils?????
Re: 8v turbo ecu
Sorry, the above post is for the series 2. The 440A is for the 16V normally aspirated engine
For series 1 it looks like Microplex MED601B for the 8V turbo.
The "B" uses a distributor and the "E" has the no distributor (twin coil wasted spark system)
