Thanks for advice on a checklist to overcome folowing problem:
My Monte S2 accelerates nicely up to 3500rpm but goes into a dip between 3500-4000rpm. Above 4000rpm, acceleration is impressively good and even better since I installed a CSC exhaust.
The hesitation between 3500-4000rpm also occured with the standard exhaust and is apparant in all gears.
Can anyone let me know what the most sensible sequence of checks are that in I need to do to find the cause?
irregular acceleration
Re: irregular acceleration
hi mark
does the problem occurs at certain revs or isn't it rather depending on the position of the throttle flap.
if your running a weber datr carburator this problem ist quite common. i've had it too and i finally changed
to dcoe.
the datr is a two barrel carburator. the second throttle flap opens, when the throttle pedal is about half way down. at this point the problems may occure.
i didn't manage to solve it.
with the dcoe no more problems. engine runs perfect at all revs and is more powerful at same consumption
best regards
claude
to dcoe.
best regards
claude
Mark,
I had a similar problem that after lots of testing turned out to be a double firing on cylinder number 3...found it by watching each plug wire using a timing light on a thin paint mark I made on the outer rim of a cam pulley...the window on the trans was hiding it from me...The distributor was in need of service and I fitted the marelli pickup and trigger rotor and coil from a standard fiat spider so as to get myself into the 20th century...nicer start up and works well...The latest change was some F44 emulsion tubes that have a smaller outside diameter...all holes are the same as the stock F30. (which is the weber 61450.229) ..this give acceleration reserve...smoothed my acceleration imensely...Sorry I don't yet have the last three digits for the F44...but the first five numbers are important as the F codes are used over and over... Regards,
John
