Cam timing
Re: Correction V angle
Just to be clear here - this V angle is of the piston bore - in some of the engines this is not the same as a line to the center of the crank. I mention this just in case someone's brilliant machinist starts to take the crankcase and tries to line up the angles....
Geoff Goldberg
1952 B20 s.2
1957 B24 s.6
1959 Appia Berlina s.2
1952 B20 s.2
1957 B24 s.6
that´s correct. You can find the sketch also in the drawing of the lancia patent about this item.
regards
Andreas
regards
Andreas
Re: Cam timing
Hi to all Lancisti from Greece. I got recently a coupe 1.3 S of 1975 3rd series in completely original status and 99000km on the clock. Just started restoration and I would like to ask about timing process... My camshafts don't have vernier so adjustment is only possible with timing marks, so far so good. I am wondering, if so, I can adjust my valves directly to the operational gap without the intermediate method of 2.2 mm gap, am I right?
Thanks in advance!
Thanks in advance!
Re: Cam timing
Putting crankshaft at TDC and the camshafts on the mark is ok. I would at least check with the 2,2 mm method on cylinders 1 and 4.
We also print a 360 degree disc to fit the flywheel (or the pulley if the engine is still in the car) and check all 4 cylinders opening and closing.
Re: Cam timing
Thank you so much! I have rebuilt so far my FIAT 124 , Alfa Romeo 105 and Triumph but Lancia is really unique in its engineering, its my first Lancia and unfortunately there is no so much literature around... So, I will come back with more questions for sure!Huib wrote: ↑06 Sep 2021, 10:21 Putting crankshaft at TDC and the camshafts on the mark is ok. I would at least check with the 2,2 mm method on cylinders 1 and 4.
Re: Cam timing
Always welcome.
Here the link for printing the disc.
https://www.blocklayer.com/degree-wheel.aspx
I always print it on ultra high gloss A3 photo printer.
Re: Cam timing
That's perfect! I have seen that you are dealing with 123 ignition distributors as well. I am very happy with them in my FIAT & ALFA ROMEO, I am using BT version for both, due to the fully customizable curve possibility and immobilizer option. How we can elaborate on this? Can I send you a PM maybe?Huib wrote: ↑06 Sep 2021, 13:56 Always welcome.
