crankshaft dynamo pulley dimensions
Hello, I am looking for the dimensions of the crankshaft pulley for the series 1 dynamo system. I know that the series 2 has a 14cm pulley so I assume that the series 1 must be smaller. thanks
Re: crankshaft dynamo pulley dimensions
I can check mine. I'm taking You need the external diameter, correct?
Thanks very much, i need external diameter and face diameter. Best regards.
Hi,
not too sure what You mean with "face" diameter, but the external one is 118mm, at least on my car!
luca
luca
